Last Electric WP ? i promise!
Old May 15, 2003 | 09:27 PM
CamaroRob97's Avatar
so guys i just want to be sure... the shaft that comes out of the block (and goes in to the metal sleeve which fits into the back of the WP) stays in the block right? cuz i can't even figure out a way to remove it, but i just want to get a second opion.
Thanks!
Rob
Old May 15, 2003 | 09:43 PM
97 RedSS's Avatar
I used a hammer to remove mine..Its not needed anymore unless you plan on converting back again..
Cody
Old May 15, 2003 | 10:01 PM
4th-gen-formula's Avatar
It's best to just leave it in. To remove it you must take the timing cover off, which means you'll have to replace that gasket, and then you'ld need to plug the hole in the timing cover. Just leave it in. Remove the metal sleeve that connects it with the waterpump though.
Old May 15, 2003 | 10:17 PM
Lunarson's Avatar
I just left mine in too, it'll be fine or should I say I haven't read where someone has had a problem with one yet.
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
