Can I make the 4 channel ABS work on my 95? Need to!
Old May 14, 2003 | 09:56 PM
bunker's Avatar
Ok I'm going with a Ford 9" rear end & you can use ABS if you have the 4 channel system, now I have a spare 97 rear end with the 4 channel abs that has the abs gears on the sides instead of inside the differential, now my question is, can I make my 95 Trans AM which uses the 3 channel abs converted to the 4 channel abs? I have the reluctor gears & everything on the rear end part, what else needs to be change to do the swap? thanx guys.
Old May 14, 2003 | 11:34 PM
bunker's Avatar
TTT
InfernalVortex
Jan 17, 2015 09:35 AM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
siguy
Nov 27, 2014 10:07 AM
Brian Demeter
Aug 17, 2002 08:07 PM
