View Full Version : LT1 Based Engine Tech
- Ok, so I've got this annoying squeak...
- power lose?
- Airfoil
- Thought my converter was stock but...
- Which should I get?
- Stock steel vs 1LE for drag racing...
- 58mm Throttle body
- Header Bolt Argghhhhh
- An open in a ground wire, will it still ground?
- Old time jerry rigging
- Why the hell has no company made a complete, cheap, reliable opti eliminator?
- Designed to leak oil?
- Lifter valley screen kit questions, mindgame, bret?
- What kind of transmission mount to get?
- Is there a message forum for Pontiac Grand Prix?
- Ok my car has some serious problems
- Best brake pads for 17" rims???
- Richmond 3.73's... how much "whine" is normal?
- torque arm
- some codes
- Oil Gage at 80+ any answers?
- Throw out bearing
- wierd noise
- Manual Fan Switch owners inside.
- Extremely Hot Trick Flow...
- opti questions
- Xe 224/230
- Where to get MSD universal fit wires??
- some more longtube install prep questions
- Changed Wires and coil Trouble Code?
- My HPPIII Problem and Yours LIST THEM Please*
- Woodurff Keys???
- What's causing problems?
- I am gonna have to fix IM leak :mad: ...
- Corvette magnesium wheels
- 75/25 water + coolant okay for winter
- MadZ28.com ownz you!
- Flushed Radiator, now got small problem.
- speedo off?
- I love my LT1!!!!!
- Got my SLP Bolt-On SFCs installed.. WOW
- Need scan help in Louisville
- best bang for the buck for a 1993 automatic transmission??
- BMR Bolt In Relocation Bracket Install
- ok, my turn to get cam! which one.
- Anyone know Lloyd Elliots mailing address?
- Throttle body spacer worth putting on?
- Dynabatt battery? Bolt in and go??
- '97 Suspension question
- Hotcam guys.. In here Please
- need close up pics of engine!!!please
- transmission problems
- Loud clunk and Vibrations form under Car
- I couldnt be more pissed
- Borla Y pipe
- Tire wear
- Alright help me get this hesitation fixed details inside..
- Shrader valve fitting
- How much Hp is a computer tune worth???
- 58mm t/b gains on 12.5:1 383 stroker
- aside from cam specs on a N/A car, how hard of a redline can the bottom end handle?
- A/C fuse problem. Any ideas?
- cloyes and timing chain cover clearance?
- Canton pan fitment issues?
- A/C questions
- Help please..
- corvette converter
- Electrical Wiring Help for a switch
- Keyless Entry?
- Why is there so much play in the throttle?
- 9 degrees knock at idle, 6 at WOT, about 3-4 at cruise
- finished lt install, ok to run w/o O2s?
- New springs for LT4 conversion kit
- any way to get rid of eltronic shift on 4l60e
- switching to th400 ?'s
- vibration in clutch
- why cant i run 4:10's in a a4
- Skip Shift in 6 Speeds
- Tie-Rod
- O2 Bungs location?
- Header Question
- Does non mandrel pipes make that much of a difference?
- who is running a Transo go shift kit and a billet servo 2gether?
- Clutch Cellonoid
- Book...
- Hypertech 160 Powerstat
- Shocks -need new rears -affordable options?
- BMR k-member and LT's
- Need Help Quick
- Wiring Question...need help ASAP
- i really need your guys's opinions... what would you do?
- LTCC coil per cylinder converter
- test?
- Starter Problem
- O2 sensors
- who ports LT4 heads?
- Impalla SS Gasket - Does Summit sell it?
- Long tube install ?'s
- LS1 vs. LT1 Exhaust Compatibility
- ARP Head Bolts
- slight problem after cam
- 93 guys only, with cams
- OBD1 PCM on OBD2 z28
- Need help ASAP
- coolant gone, dunno where it go
- Plugging water pump hole on timing cover?
- Trans Tailshaft
- reversed?
- I have A few tranny questions, Please try to help me
- WTF is up with my water temp gauge?
- 12 Bolt with 1350 yoke..whats ujoin do i need.
- is this supposed to happen?
- Sorry about remove cats post
- Remve the cats
- Removeing more emissions
- Screw in valve cover Breather for LT4 valve covers?
- rattling?
- Fuel Pressure Problem... need help fast!!
- How much Break in time?
- thump when accerating...not a broken transmount
- Very slow acceleration
- Low-Temp Thermostat
- Whats Best Exhaust?!?!
- HELP Exhaust
- EGR blockoff plate part #
- whats a good brand for piston rings?
- heads/Hotcam program
- does not idle after header install
- HOOKER HEADERS longtube for 93+ TA and Z's (are they for real?)
- What do you think about LS1 speed inc.(Shamburg IL.)
- t-top fastener
- What would turn engine oil milky?
- Rear end Swap
- what do u think of this 355 build up?
- help me piece together a 355 rotating assembley!!!!
- Running Tempature
- I'm so sick of my car...
- skip shift question
- Help Me Please....
- Going on a diet......
- spark plugs?
- Buying Enkei 17x9.5's, what size tires will fit perfectly?
- I Need More For Calendar
- Doing an oil change, first time on my baby
- If I put mt CATS back on...will be SES light go off?
- Removing air pump and hoses?!
- Security light???
- spark plugs maybe stuck
- Choice on Valves, Manley, Ferrera, LT4?
- 3rd Gen Tq Arm on a 4th gen
- POSI/Limited Slip
- wiring problem
- Can OBDII be tricked into thinking an EGR and AIR pump exist?
- Man! MSD coil PITA!!
- 1LE Part #s
- High rpm miss
- XE230/236 = 20Hg of MAP at idle? WTF!!
- PA RACING TUBE STYLE K MEMBER AND LONGTUBE's
- catback & cai, what next?
- Chrome Valve covers??
- My LT1 is SLUGGISH when warmed up!!!
- MSD Dig 6 VS. Tranny Tach signal
- I need sensor part #'s....
- MSD 8.5 Universal with Made For You OVC Looms
- When going from 7mm to 8mm plug wires
- Funny small stumble only in 2nd gear?
- Is there more than one tranny mount?
- Crate motor
- Help!! No First Gear In A4 Trans !!
- SES light question
- Opti Help~!
- Newbie Tire Question
- o2 sim question
- HP/Torque #'s
- 3.42 gears
- Plugging opti hole on timing cover?
- My electric water pump went out!!!
- electronic spark control ?
- Moser 9 inch
- Horn
- plug wires and waterpump
- Died in the middle of traffic!
- gauges
- Factory keyless entry reciever wiring question..
- New Way to Clean Inside Your Engine
- iac valve on 97 SS
- how many 02 sensors?
- well shoebox and everyone opti did not fix low rpm miss im so lost???
- ? on tires. Balancing.
- What's the best shift point for stock A4.
- What are the symptoms of a bad egr valve??
- Front Skinnies
- What Next?
- Help Me With Engine Miss
- Should I get better heads?
- Wiring Diagrams Needed!!!
- whats going on? need help
- What will happen is some high temp gasket sealer gets in my intake??
- RT Y-pipe for SLP headers and Borla catback ?
- what?
- Check out these LT1 Timing Sets
- HOw hard is it to replace 2 bolt mains with studs?
- Car feels sluggish after xe218/224 install, NEED HELP!
- Summit Forged Kit??
- Coolant Level Sensor
- MAC header torque gain?
- How much do GFX weigh?
- Realistic gains off headers
- Rear end oil change, how?
- 4l65-E
- Tried to program my pcm
- What size tranny cooler for 2800stall??
- Grounds on 95 LT1
- motor mount problems.........bolt wont slide out!!!
- Part number for cloyes chain?
- How much is too much? SMOG?
- '95/'96+ LT1 differnces?
- Eliminating dash rattles
- hpp question
- Is the IAT sensor gasoline resistant?
- what tools do you use for porting?
- Lloyd Elliot LT4 head flow #'s
- Ground clearance w/JetHot LTs
- I need some questions answered quick about my bolt SFCs, shop putting them on today
- Anyone?
- FREE MODS (Or almost free)
- What kind of numbers should I get from this cam?
- engine codes..
- Running out of Gas?
- p1441
- More power with OBDI over OBDII?
- Need Help! Brakes Went Out!!
- Fuel pump won't properly work
- Suspension ?
- Reading spark plugs after WOT
- Dynomouth exhaust too restrictive for my needs?
- MAC problems
- Cheapest way to the 12's?
- free mod ?'s
- S.P.E.C Stage 5 =O DAYUM!!!
- anyone coating their y- pipe ?
- SES light when cut-out is open??
- Grrrrrr...
- OBD-I Conversion?
- M6 Wiring Harness ?
- Heads/cam/headers and ran 13.4 :(
- Will a bad egr cause a ticking sound?
- SRT 4 vs LT1
- brakeing question
