Moser 9 inch
Old Jul 17, 2003 | 05:33 PM
LJ93Z28GM's Avatar
Moser 9 inch
Just wondering if anyone else has poor road manners after the install. I have had my 9 inch in for over a year and it is a great product and install was easy but it does sit up higher since the spring perches are higher than a ten or twelve bolt.
What i am wondering is if anyone else hears a thud or hard hit when going over bumps in the roads at speed. Mine seem to be hitting the jounce bumpers since you can see the paint is clean in the spot below the bumper.
I am running V-6 springs and Hals. I am just wondering if everyone has the thud or not. I am going to try and swtich to some rear lowering springs that I have and adjust the Hal's.
I am not sure if i can take some material of the jounce bumpers to give the rear more range of movement due to the exhuast setup.
Old Jul 17, 2003 | 05:48 PM
rskrause's Avatar
Moderator
Is your DS too long? The slip yoke may be bottoming.
Rich Krause
Old Jul 18, 2003 | 12:28 AM
LJ93Z28GM's Avatar
The was the other item on my mind. Is it necessary to have a short shaft for the moser 9 inch? IT still seems to be hitting the bump stop. If the shaft was to long would that not stop travel.
I kinda of disregaurded it since there was marking from the bump stop.
Z Power
Sep 19, 2015 11:19 PM
rvonsternberg
Sep 14, 2015 11:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
zk06
Sep 9, 2015 11:39 AM
maverickmk
Sep 1, 2015 09:17 PM
