MSD 8.5 Universal with Made For You OVC Looms
Old Jul 17, 2003 | 07:35 PM
TDog's Avatar
Anyone using this setup...
Just wanted to make sure I could get the 8.5 wires to fit in the Made for You Looms...
Thanks,
TIM
Old Jul 17, 2003 | 07:39 PM
Ryan 97 Ram Air T/A's Avatar
Have the exact same setup. I had to drill out the holes to accept the wires, but that is easy. What was harder was getting the MFY looms to fit around the egr tubes on my dual cat car.
Old Jul 17, 2003 | 08:20 PM
TDog's Avatar
Thanks...
Thanks for the response...wish there were some looms out there that needed no modification...
However..a little drilling out never hurt anyone...
-TIM
Old Jul 17, 2003 | 08:27 PM
AsianSensation's Avatar
I had to drilled my looms out too for the 8.5mm MSDs when I went OTVC routing. I'm ditching them in favor of Talors for side mounting looms Thunder Racing sells. Part number MSD-32129 at Summit Racing for Universal wire set with opti boots.
Old Jul 17, 2003 | 08:32 PM
TDog's Avatar
Thanks...
I've got another question...If I go with LT4 valve covers...will the Made for you looms still fit...I'm just wondering if the center bolts supplied with the M4Y looms will still work...not sure if the LT4 valve covers would cause a problem...
Thanks,
TIM
Victor Lamb
Aug 26, 2017 02:52 PM
TitoPR221
May 26, 2015 12:20 AM
BLK1997Z28
May 7, 2015 03:01 PM
Joes96z
Dec 13, 2014 07:48 PM
GigaMp3z
Feb 20, 2003 02:57 PM
