ARP Head Bolts
Old Jul 18, 2003 | 11:22 AM
DjArcadian's Avatar
ARP Head Bolts
I'm pulling my heads soon. What are the part numbers for a set of ARP head bolts? Engine is just bolt ons. No cam or head work.
Old Jul 18, 2003 | 11:24 AM
DjArcadian's Avatar
BTW, what exactly is the difference between a head bolt and stud?
Old Jul 18, 2003 | 12:08 PM
kirschman's Avatar
#134-3601 is the part no. As far as the stud and bolt ? goes, well, its just that. If u get a stud kit the studs screw into the block, then u use nuts instead of bolts to snug em down. The studs are waaaay stronger than bolt, but, the bolts should work fine. I'm not sure if u can use studs or not if the motor is in the car still, not enough room to get em to clear the studs when u install them. Get the ARP's, I just used em and they are just fine. Since the factory bolts are torque to yeild, wonder if the ARP's are also?? I might have to pull my heads back off and I'm curious if I can re-use my ARP bolts, hmmmm.......
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
