Wiring Question...need help ASAP
Old Jul 18, 2003 | 02:09 PM
gb95zconv's Avatar
OK.....I almost have everything buttoned back up on in engine install. I have a couple of wires that I cant seem to figure out where they go. On the passenger side the harness coming off the fender wall has three wires....I know one of them is for the O2 sensor, but where do the 2 smaller black wires go. Im thinking either starter or to a ground point. TIA
Old Jul 18, 2003 | 03:23 PM
There may be some confusion. I think what you might have are purple, black and blue wires. The O2 has four wires in a flat connector going to it.
If you have the three wires mentioned above, the purple goes to the outside small terminal on the starter, the black goes to a little ground lug on the block above the front of the starter and the blue should have a big plastic connector that goes to the knock sensor.
Old Jul 18, 2003 | 03:42 PM
gb95zconv's Avatar
Duh....yeah I ment to say one was the KS instead of O2....too many hours out in the heat. Thanks a ton shoebox.....should be able to fire this thing off thisevening.
Potent77
Mar 16, 2022 12:13 AM
Heathen1
Jan 2, 2016 04:27 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
Potent77
Apr 1, 2015 12:45 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
