Low-Temp Thermostat
Low-Temp Thermostat
Who besides hypertech makes a 160 degree thermo for our cars? I just found one made by Mr. Gasket that only says it's for a chevy. Does anyone know if this will fit?
Beleive it or not a Hypertech 160 stat is really a "moto-rad" brand stat in a Hypertech box !! Once you open the Hypertech box and look at the stat it has MOTO-RAD stamped right on it!!
Moto-rad 160* stats are like $12.00 or so... You can buy it out of summit or Jegs!! Or just go to your local parts store and pick up a 56mm 160 stat and new rubber gasket to go arround it and put it in....
There is nothing unique about LT1 stats so dont be fooled to think other wise because of reverse flow cooling...or just spend $25 buck on a Hypertech and $5 on some KY jelly cause your gonna need it !! J/K
See Fred"s post bellow as he corrects me on my ignorance.
Later,
Jason Coffman
JDC PERFORMANCE
Later,
Jason Coffman
JDC PERFORMANCE
Later,
Jason Coffman
JDC PERFORMANCE
Later,
Jason Coffman
JDC PERFORMANCE
You aren't going to damage the engine with the wrong one, but they do not function the same.
OK..OK I'm sorry I was incorrect but that is why we have this board. Thank you for showing me that link Fred as you imput is allways great and correct based on tec facts.
Can you explain why the small orffice gets closed off while the state is open?? Does it close off the TB routing or something??
I have a question on the 160 degree stat. I was told yesterday, that putting a lower stat, that it could possibly retard your timing. Is this possible? Or do you have to reprogram your PCM?
Tuff.
Tuff.
The old SBC thermostat will fit, but you lose effiiciency. It is not worth a few bucks to take a chance on an overheated engine, given the delicate nature of the head gaskets. MHO.
Tuff.
Tuff.
Originally posted by shoebox
Making it cooler is not going to retard timing. No reprogramming is mandatory. You can read some stuff about the 160º thermostat here.
Tuff.
