4l65-E
Originally posted by treyZ28
isn't that the FWD tranny in Grand Prix and such?
maybe i'm mixing stuff up. anyone, if u want to burn time and money, at least do a 4L80E
If a 4L65-E is smaller than a 4L80-E, it should fit with some modification at most. There is at least one individual out there who has a 4L80-E in his Fbody--do a search, might find it. I recall reading his post and he had to do some cutting--might have been the Advanced Tech forum.
a couple of guys did the 4l80e swap it will fit in the tunnel with a little hammering to fit the cooling lines not bad it will bolt up but you need to control it with an after market computer due to the differnt sensors inside the trannsmission the computer is made by tci it cost 1000 dollars! the transmission its self is cheap and their is high performance rebuild kits. only draw back is the high parastic drive train loss and the weight of the trans it weighs 100 pounds more i think you only need to do this swap when working with a high boost motor or large doses of crack thats my 02 on it
I think the 4l65e's only difference is the reaction gearset. It has 5 pinion gears instead of 4. It will fit in the factory 4l60e case. It is used behind the 6.0 trucks and I think the H2. GM dealers should have the parts.
ChrisFrez
10-30-2012 10:13 AM
formula79
19
12-02-2004 01:07 PM
1fastdog
13
07-30-2004 08:58 PM
