Dynomouth exhaust too restrictive for my needs?
Old Jul 17, 2003 | 05:36 AM
magius231's Avatar
I'm planning on going with the Dynomouth exhaust, for those of you that don't know its basically a Dynomax bullet muffler welded into the stock I-pipe, then the stock muffler is eliminated and a Y is fabbed to keep the dual functioning tailpipes. I am a little worried that the stock 2 3/4 I-pipe won't be enough to keep up with my engine (very soon I am going with Lloyd Elliot heads and a cmotorsports recommended cam) and that I would be better off fabbing up a true dual setup or a 4" cat back...anyone have any thoughts on this?
For those of you wanting more info on the Dynomouth, here is Ratio411's site on it:
http://www.cardomain.com/member_page...=215971&page=2
Old Jul 17, 2003 | 10:15 AM
brandboZ28's Avatar
I know of a couple of LS1 guys running big cams running the Dynomouth with the stock I-pipe and putting down great #s. Im also have it and love it. Im sure a 3 inch pipe would help out and a true dual would be great but Im not sure how much the stock I-pipe will end up hurting you. Personally when I go with heads and cam Im gonna run duals.
Old Jul 17, 2003 | 10:36 AM
Serial Thriller's Avatar
The farther away a restriction is from the exhaust port, the less effect it has. That's one reason headers give a better gain than just a catback. So the question is, what do you have before the i-pipe that may be your limiting factor? Are your "SLP shorties" the dual cat headers? And are you running cats?
Also, you don't 'need' a 4" exhaust until you get in the ~600 hp range.
Old Jul 17, 2003 | 03:08 PM
magius231's Avatar
they are single cat headers, still have the cat on it (doubt I will remove it, just doesn't seem worth it to me).
What I'm worried about is losing 10-15HP from having a 2 3/4 pipe instead of a 3" or bigger pipe when I put the cam in there...
Old Jul 17, 2003 | 03:24 PM
The SLP y-pipe is 2.5". And since you're going a cat, there shouldn't be much difference between running a 2.75" or 3" intermediate pipe, especially if you go with a muffler as free-flowing as a bullet.
Old Jul 17, 2003 | 10:33 PM
magius231's Avatar
at what point do you think the 2.75 pipe will become a restriction? Just wondering if I need to do it later...
Old Jul 18, 2003 | 09:42 AM
magius231's Avatar
TTT - anyone?
MadMav
Jun 15, 2015 09:51 PM
May 15, 2015 10:43 AM
mritter1965
Exhaust System
Feb 15, 2015 07:31 AM
brandboZ28
Jan 31, 2003 06:19 PM
