aside from cam specs on a N/A car, how hard of a redline can the bottom end handle?
I have a question concerning the bottom end limits. Many people with the stockers tend to run their engines up to 6500. Can the bottom end handle that, and can it handle it.. say once or two times a week? I guess im trying to ask are there any long term effects (within a 100,000 mile period). I want to know because I have a scat 9000 stroker crank and shot peened factory rods with hyperutectic pistons.. which should be better than stock. I am talking about all motor .. no spray or blow.. how much can the bottom end handle without having any problems?
Shifting at 6500 RPM is NOT fine.
A stock LT1 rotating assembly is NOT balanced past 6000 RPM. I'm sure there are many people who still shift high into the 6XXX RPM range without a problem, but those are exceptions. Over-revving can lead to problems down the road.
Without Cam specs, it is useless to even consider rasing the rev limit into the 6000 RPM range. A stock LT1 isn't going to make power past that anyways.
since 1954 when the SBC came out for the 55 model year the only thing holding it back from being a "Revver" was the valve train
take care of the valve train and the rest will follow.
Then again I think the rest of you should never rev past 4k. that way you will never be in the lead
take care of the valve train and the rest will follow.Then again I think the rest of you should never rev past 4k. that way you will never be in the lead
My cam specs are posted in my sig. The powerband on the cam doesnt really kick in until 2k or so. So.. as long as I dont rev past 4k and shift at 6500 I should be ok? I had my crankshaft internally balanced at my machine shop with the flywheel and balancer on it. Since I have my rotating assembly balanced correctly, will the 6500 redlines be easier on my engine now?
As for shifting at 7000, whew thats too much for me. I get pretty nervous around 6500 already (on the stocker). Now I have the scat crank, and I know its stronger than the stock crank, a better kind of cast.
Thanks for the replies!
I was spraying my stock bottom end up to 6700 rpm and when I pulled it apart it was still doing ok
Now with stock crank, 6" rods and forged slugs, I'm running it to 6700 again on the spray.
Elis hit the nail on the head, a good valvetrain setup is a must. Also watch your oiling, some guys have trouble starving the motor at high rpms.
Now with stock crank, 6" rods and forged slugs, I'm running it to 6700 again on the spray.Elis hit the nail on the head, a good valvetrain setup is a must. Also watch your oiling, some guys have trouble starving the motor at high rpms.
Brandon Wittmer
Dec 20, 2014 09:51 PM
