Lloyd Elliot LT4 head flow #'s
Old Jul 17, 2003 | 10:12 AM
Kuma's Avatar
Just got my #'s back from Lloyd. I asked him to do a "street" porting job rather than a "full port" since he said it would give me better low end power. Later on if I go for a supercharger or turbo I may have them touched up a bit to get the last few cfm.
Int. before/after
.100 62/66
.200 125/132
.300 177/186
.400 218/233
.500 243/270
.600 240/283
Exh. before/after
.100 24/25
.200 89/99
.300 123/131
.400 144/152
.500 158/167
.600 163/175
Old Jul 17, 2003 | 01:43 PM
llafro's Avatar
Interesting numbers. I compared them with my ported heads from Lloyd. Something's wrong with the numbers for your .100 exhaust. Maybe they are the .050 numbers?
The LT1s stack up pretty well in this case.
BRAD
LT1 - Stock
lift Int./Ex
.100 59/42
.200 110/79
.300 169/115
.400 206/135
.450 213/141
.500 210/144
.550 210/144
LT4 - Stock
lift Int./Ex
.100 62/24
.200 125/89
.300 177/123
.400 218/144
.500 243/158
.600 240/163
LT1 - max port
lift Int./Ex
.100 64/55
.200 133/107
.300 185/137
.400 231/162
.450 247/175
.500 263/182
.550 272/187
.600 278/191
LT4 - street port
lift Int./Ex
.100 66/25
.200 132/99
.300 186/131
.400 233/152
.500 270/167
.600 283/175
Old Jul 17, 2003 | 02:39 PM
bigdreamZ's Avatar
Hey Kuma, are you in Los Angeles are as well? I was talking to Brad via email about his setup passing smog and he has not had to test it yet. Are you planning on passing smog with your new setup? What cam will you be running with those LT4 heads?
Old Jul 17, 2003 | 04:49 PM
bigdreamZ's Avatar
OK I am an idiot I thought Lloyd Elliot was local. Nevermind. Anyways my other question is what cam are you planning on running with those heads?
Old Jul 17, 2003 | 05:13 PM
RealQuick's Avatar
BRAD
I think we got the full pport from Lloyd, while he got a street/econo job
Old Jul 17, 2003 | 05:30 PM
drewstealth's Avatar
Does anybody have a link for lloyd elliot
Old Jul 17, 2003 | 05:58 PM
Kuma's Avatar
He was gonna charge me the same regardless of street or full port, but he recommended a street port for a fat powerband, esp. since I don't plan on running it above about 63-6400 rpm in its current form.
I'm just gonna run the Hotcam with it for now, never had a car that put out this much power before as is...may go with S/C or turbo later after rebuild.
Yeah, I thought somethin was funky with the .1 exhaust...
Old Jul 17, 2003 | 06:19 PM
FacelessZ's Avatar
Yea I'm about to have Lloyd port a pair of stock LT1 heads to max...he claimed ~275/190ish....200cc.....$1200.....
Doesn't seem like too bad of a deal...
While we're on it...anyone care to guess my current hp/torque numbers from the mods in my sig....
Thanks!
Old Jul 17, 2003 | 06:59 PM
Jesse_Boyer's Avatar
Kuma and llafro:
maybe i'm the only one that's noticed, but you have EXACTLY the same flow numbers... EXACTLY.
I think a mistery is afoot... unless he's a machine (CNC) how in the world he got the EXACT same intake numbers on two sets of heads is a mistery to me. So, are these heads CNC'd or hand ported?
LT4 - street port
lift Int./Ex
.100 66/25
.200 132/99
.300 186/131
.400 233/152
.500 270/167
.600 283/175
Int. before/after
.100 62/66
.200 125/132
.300 177/186
.400 218/233
.500 243/270
.600 240/283
Old Jul 17, 2003 | 07:04 PM
llafro's Avatar
They are the same because I copied them from his post. The LT1 numbers are mine, and the LT4 numbers are his. I just wanted to put them all together in the same format so people could see the comparison. No mystery here.
BRAD
Old Jul 17, 2003 | 07:24 PM
llafro,
good to hear. I thought for a second that Lloyd was posting flow numbers from one set of heads for all his heads. I should have known better. Sorry for the confusion, its been a long day.
Old Jul 17, 2003 | 09:08 PM
PoorMan's Avatar
FYI: Here are my LT1 heads from Llyod with larger Ferrea Valve. I am pleased.
http://community.webshots.com/photo/...77230108xTZGxf
http://community.webshots.com/photo/...77230457wwtCNM
http://community.webshots.com/photo/...77272276EJwkpN
http://community.webshots.com/photo/...77272403eACymd
Jeff D.
Old Jul 17, 2003 | 09:11 PM
Kuma's Avatar
I agree the LT1 stacks up well here, esp. with the full port. Acc'ding to Lloyd, the LT4 will go up a bit higher ultimately, to a little over 290 at "full port," but it sounded like it wrecks the low end of the powerband.
Seemed to me like the .6 value for exhaust on the LT4 heads is a bit low, esp. considering the values listed on http://www.malcams.com/legacy/misc/headflow.htm
Old Jul 17, 2003 | 09:16 PM
bigdreamZ's Avatar
Hey PoorMan what is the flow on those heads? Are they max port LT1 heads? What did you dyno?
Old Jul 17, 2003 | 09:17 PM
96z's Avatar
96z
Nice.
