75/25 water + coolant okay for winter
Old Jul 18, 2003 | 11:14 PM
pelebkf's Avatar
I was wondering was is the lowest possible water to coolant ratio for the lt1 with dexcool in south carolina. Will this be okay for the winter or is there any other product that you can use to make the water consentration higher?
Old Jul 18, 2003 | 11:19 PM
25% concentration of ethylene glycol will only provide freeze protection to +10degF. Is that low enough for SC?
Old Jul 18, 2003 | 11:21 PM
pelebkf's Avatar
That will work for SC is that dexcool that you just mentioned or is there anything better to use
Old Jul 18, 2003 | 11:25 PM
Dex-Cool is "ethylene glycol", as is the conventional green coolant. The only difference is the anti-corrosion and lubricating additives.
There's always Evans NPG, but that uses no water at all, and requires a major cooling system change.
Evans NPG
Old Jul 18, 2003 | 11:28 PM
pelebkf's Avatar
When you say major change what are we looking at? Flushing the system?
Old Jul 18, 2003 | 11:30 PM
Different radiator, and no pressure cap.
Do a "search".... there has been a fairly extensive discussion of this in the past, although I haven't seen the subject come up in the last 6 months or so.
Z28Freak86
Apr 30, 2024 05:37 PM
blac94Z
Feb 15, 2021 09:43 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
00Camaro3.8
Nov 13, 2001 08:42 PM
