Remve the cats
Remve the cats
Hello, I am new here but Ive been reading alot on this board.I bought my car from a friend and the car had been sitting for 3 years.I had all the opti,spark plug and wire problems.Converted to vented with great info on this board,thanks everybody. Now runs great but I would like to remove the cat ,do I need to "fool the O2 senors or what else needs to be done.No checks done here.
Honestly, I know some ppl will disagree BUT. Leave the cat in!! I have a 1994 TA GT, and it has the 1 cat setup, its gutted and its UNREAL how much low end power you loose, its better in the top end though. Your realy just looking for problems, though it wont damage the motor. I think you should leave it in. Plus the pops that sound like fire crackers exploding agianst metal kinda sounds horrible when you rev it up. Upto you though. Plus if you add a exhaust, it will be way to loud
As long as you have no exhaust leaks..my car has rarely had pops/backfires and only if I let out at the top of a gear suddenly. Good luck regardless of what you decide.
if you guys want to remove the cat i strongly agree that you should put a 3" cut out in its place. i had the usual popping noises with my flows but now its all better
i lost some low end w/ the cut out but up top i gained a lot, now i trap around 4-5 mph higher than with the cat there. i'm shooting for a 13.6-13.7 this time around but i need a helmet. i used to trap around 96-97 now i trap around 100-101.
Hmmm, I don't think I'd go taking off the cat just yet. Especially if you're still running stock manifolds. I would bet at this point a nice catback would be a good mod. Removing the cat seems to be a mod that everyone jumps on just because it's free. Don't get me wrong, I have removed my cat, but I had all the bolt ons when I did it, and had plans for the heads/cam at the time.
John
John
John
John
After you get long tubes, running offroad pipes instead of dual cats will give you about a 5 horsepower advantage. I'd go that route only because it's a lot cheaper than buying high flow cats. As for now, I'd leave the cat in.
Here's what you do. Cut off the cat and weld in a straight piece of pipe in its place. If you have a single cat car with only 2 O2s (left and right side, before the cat) you don't need sims. You only need that if you have O2s after the cats. Don't just hollow out the cat. That's not good because the pipe is smaller then larger then smaller and it messes with the flow. That's probably why some people are not liking !CAT. There is no reason to have cats on a car that is not in an emissions enforced area.
well I took off my cats when I installed my longtubes, but have since gone back to them, because the smell is 100 times better-especially if you have a cam/heads combo. I wouldn't remove it unless you are throwing on the longtubes, this will also make a bigger difference when you do the headers, since you'll be feeling more horses at once instead f a little at a time. The cats are cheap to buy, I got mine off e-bay for 50 bucks a pop and I don't have to worry about recieving a 5000 dollar fine. If you need the extra power, a cutout will be more benifical. I personally like the electric kind, since you can intimidate the driver next to ya at the light
Sep 11, 2015 09:44 AM
