thump when accerating...not a broken transmount
Old Jul 18, 2003 | 01:57 AM
user guest 45's Avatar
getting a thump when i accerate hard...checked transmount several times...its perfect any ideas????
Old Jul 18, 2003 | 02:49 AM
GreenZ28in503's Avatar
Torque arm?
Old Jul 18, 2003 | 03:46 AM
camaronutt's Avatar
Yeah, try the torque arm. Also look at the lower control arm bushings. My Iroc had a bad control arm bushing and did the same thing. Maybe a motor mount. Hope nuthin majors broke.
Old Jul 18, 2003 | 04:34 AM
predator's Avatar
loose swar bar where it mounts to the axle ...if its loose it will rotate a little and made a popping noise because of the friction
Old Jul 18, 2003 | 08:01 AM
firepheasent's Avatar
I know you said its not the tranny mount but are you sure??... If your running a stock mount it compresses over time and will appear to look fine but when you floor the car it streach out severly and let the tranny stop hit the tunnel. It will not break the mount on alot of M6 cars since we have the little bumb stop on the top of our trannys.
I only suggest this because I just went thought it. It was fine untill I put on Drag radials and stressed it to the max and then came the big BANG.
Later,
Jason Coffman
JDC PERFORMANCE
Old Jul 18, 2003 | 08:39 AM
kmook's Avatar
Advanced Tech Moderator
Did you take out the trans mount and visually inspect it?
I have had this quite a few times, it was always either a broken trans mount or broken torque arm.
Old Jul 18, 2003 | 09:37 AM
speed76demon's Avatar
How much is a broken torque arm?? and will you lose performance b/c of it?
Old Jul 20, 2003 | 05:07 PM
mount looks perfect...how do you know you have a bad torque arm? besides it looking physical broke or bent?
Old Jul 20, 2003 | 05:15 PM
Zerosheaven's Avatar
i had a bold that connected the torque arm come off wich made it swat and hit the metal around it when i accelerated, to see if you got the same problem get under your car and try to push it too see if it will move. if it does then a bolt is probobly loose somewhere.
Old Aug 4, 2003 | 12:54 PM
still have the problem...torque arm is fine...transmount is fine... anybody please! on on hard acceleration...
Old Aug 4, 2003 | 01:00 PM
JSK333's Avatar
What about the torque arm bushing? On the tailshaft of the tranny.
Old Aug 4, 2003 | 01:42 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
u joints?
Old Aug 4, 2003 | 03:24 PM
brand new energy suspension torque arm mount....checked it out it looks fine....
put new drive shaft 1le with new ujoints about 6months ago....
Old Aug 4, 2003 | 03:33 PM
exhaust is super tight...its definatly not hitting.... anyone think it could be relocation brackets on a non lowered car?
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
mlopezart
Sep 8, 2015 12:15 PM
maverickmk
Sep 1, 2015 09:17 PM
