How much Break in time?
Old Jul 18, 2003 | 02:26 AM
96redformula7's Avatar
I need to know how long of time/mileage I should break in the new parts for. Any ways you all reccomend doing it or whatever helps.I just got installed:
New tranny casing
PI Vig 2800
3.73's
Tranny Cooler
PCMFORLESS
I know I am going to have a break in time how much?
To Whom It May Concern: Thank you for your help!!!
Old Jul 18, 2003 | 03:53 AM
QCKZ28's Avatar
here's how i broke in my 3.73's take it real easy and vary speed and load for 250-500mile and change fluid
im wondering the same thing, what kind of break in on a new rebuild tranny and Vigi TC?
Old Jul 18, 2003 | 05:32 AM
revtime's Avatar
If it is a lockup TC I was told to go easy on it for 50 lock/unlock cycles. My new tranny? I asked my tranny builder about breakin and he said quote " Thats a good tranny, don,t worry about it"
I took that to mean I could hammer on it immediatly but I been taking it easy for about 75 miles now and I got on it a bit last nite about half throttle and yep this tranny/TC combo is the sh*t. Its a conservative stall but I love it so far.
Old Jul 18, 2003 | 08:00 AM
CANTONRACER's Avatar
If gears are properly set, no break in time. But I would take it easy just in case.
Good luck!
Old Jul 18, 2003 | 09:17 AM
my94blackz's Avatar
Another vote for the no break in time an engine builder for a pro mod team once told me there really isnt any break in time for an engine.
Old Jul 18, 2003 | 09:32 AM
The whole thing of varying the speeds and 500 miles will probably be what I do unless anybody else has any suggestions.
Old Jul 18, 2003 | 02:35 PM
The engine is a whole other story. The reason for the break in for an engine is pretty dependant on the rings and setting in. If you run a tool steel, plasma moly, or chromoly, there will be very little wear if set properly up.
Now if you run a cast ring, which seals very well, you do need a break in or the rings don't set correctly.
Old Jul 18, 2003 | 03:11 PM
FireAm94's Avatar
No matter who sets up your gears you DO need to break them in. One reason for the initial (15 miles cool down for 1 hour, repeat 2 more times) is so the gears can temper. You also need to break them in for atleast another 200 miles to develop a wear pattern between the ring and pinion gears. It isn't worth taking chances....our rears are weak enough as it is.
Joe
Old Jul 18, 2003 | 07:14 PM
This is my 3rd year on my rear I setup myself. I had no break in time.
Old Jul 18, 2003 | 08:07 PM
FireAm94's Avatar
Each to his own but the manufacturers give break-in procedures for a reason.
Joe
armedtrigger
Feb 24, 2015 08:30 PM
grabbem88
Feb 13, 2015 03:09 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
97FormulaWS-6
Sep 11, 2002 11:57 AM
