Help please..
Old Jul 18, 2003 | 06:29 PM
Transamdriver's Avatar
Help please..
I am 1/2 way done with my cam install and I bought the GM extreme duty timing set to replace the stock one, I was wondering if I had to change the water pump drive gear from the stock one to the one that came with the set? They look the same and the stock one doesnt show visible wear.
I converted to an electric wp a long time ago so the only purpose that the wp drive shaft serves is to plug up the hole in the timing cover.
Thanks for any help!
Old Jul 18, 2003 | 06:41 PM
scoobysnax83's Avatar
it isn't that terribly hard to do, so why not do it?
Old Jul 18, 2003 | 06:44 PM
How do you get it out of the block? I took of the retaining plate off and it was just stuck in there like it was pressed in the block. Of course the Haynes manual doesnt tell me how to do it nor does it even acknowledge the part in the book.
Old Jul 18, 2003 | 08:53 PM
Someone please tell me if it is ok to run the GM extreme duty timing set with the stock wp gear, I just read that you need a special tool to remove it!
Old Jul 19, 2003 | 07:12 AM
TTT before I go to work.
Old Jul 19, 2003 | 09:31 AM
AsianSensation's Avatar
I used a flathead screwdriver to pry out the water pump drive gear . Had to put some muscle behind it.
Old Jul 19, 2003 | 10:09 AM
I heard a claw hammer works.
my1994z28
Parts Wanted
Jul 8, 2010 08:46 AM
SSSean
May 26, 2010 05:10 AM
SSSean
May 14, 2010 04:40 PM
