OBD1 PCM on OBD2 z28
What would I need for this? Will it just plug straight in (the OBD1 PCM)? Or Should i just get a OBD2 PCM and get a OBD1 conversion done?
Just seems like OBD1 LT1 cars have many more tuning options....
and what about cost?
thanks!
thanks!
To do this conversion, you need to get a OBD-I PCM from a 94-95 GM car (preferably a z28), and you also need to get a 94-95 style knock sensor. If you can find an OBD-I from a 94-95 z28 in a junk yard, and also get the knock sensor, you are all set. Without the knock sensor, the car runs like crap. With the OBD-I, tuning is easier and most importantly, cheaper. Good luck.
Originally posted by pillagenburn
Where does the knock sensor connect on LT1's ?
thanks
thanks
do you have to drain the coolant or anything before you swap the knock sensor?
Deadbolt24
Jan 19, 2015 01:29 PM
Jan 5, 2015 07:14 PM
