HOw hard is it to replace 2 bolt mains with studs?
Old Jul 17, 2003 | 01:00 PM
ZDriver96's Avatar
I will probably end up porting and polishing my heads. How hard would it be to replace the 2 bolt mains with 2 studs with the heads off..?
What are the best studs to use that wont give me any trouble?
Just getting an idea before i dig in
Old Jul 17, 2003 | 01:17 PM
96z's Avatar
96z
I wont matter if the heads are off. The mains are on the underside of the block. At the very least you would have to take the oil pan off. Why would you want to do this anyway?
Old Jul 17, 2003 | 02:45 PM
ZDriver96's Avatar
Oh you have to take off the oil pan huh... ah forget that... for now anyways. I want some stronger ones cuz its been a long time since my car has had 285hp and shes not getting any slower
Just wanted to see if I could add some stronger parts while the heads are off.
Old Jul 17, 2003 | 03:46 PM
Perry93TransAm's Avatar
Are you thinking head studs?
Old Jul 17, 2003 | 04:00 PM
ZDriver96's Avatar
nope i meant the mains.
But i might do some ARP head bolts...
What are the advantages to them over the stockers?
Old Jul 17, 2003 | 04:15 PM
thewinner's Avatar
arp head bolts are much stronger than stock and provide a better clamping force.
i have a set for sale 30+shipping
Old Jul 17, 2003 | 05:18 PM
Javier97Z28's Avatar
Moderator
just for clarification the 2 stud bolts are what you are referring to and they stick out the bottom of the block and hold the crank in with the main caps that attach to the studs
Old Jul 17, 2003 | 05:37 PM
thewinner's Avatar
the lt1 has 2 bolt main caps with bolts in them. they are not studs. you are thinking of the windage tray attachment stud.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
97 RedSS
Jun 10, 2003 07:58 PM
teedoff59
Aug 8, 2002 01:36 AM
