Plugging water pump hole on timing cover?
Switched to a double roller and csi electric water pump... What's the most common method of plugging the hole left in the timing cover?
Chuck
Chuck
Freeze plug, not the normal one though. Get the kind that look like the lense on a pair of glasses, (concave?) Search my user name (i cant member the size) but I found one that fits perfect. You need to lay it on the ground and just slightly flatten it with a hammer, put some RTV around the hole and tap it in. Mine fit REAL snug, not a leak in sight yet. Just take the t/c to the parts house with ya and ask em to let u go through the freeze out plugs.
