plug wires and waterpump
Old Jul 17, 2003 | 04:54 PM
harley883's Avatar
i just got my msd plug wires and trick flow elbow in today i need to install the wires they are 8.8 is ther going too be any problems installing these?i have msd seperaters too,next ?,i put the trick flow elbow on this morning and my air foil wont fit with it in its a holley air foil.am i going too have too order a different one?and im going too have too replace my coolant temp sensor in the water pump,i cant get the sensor out becauce of clearans .the socket or a wrench will not fit too get it out ,tried everything!so im going too have too pull my new water pump and take it backget another one and put my sensor in,that way my check engine light will quit coming on sometimes when you hit a bump lodges the end loose where the donkey slong broke the end off the sensor.anybody had this happen?
Old Jul 20, 2003 | 03:28 AM
D James's Avatar
I brought your post back--I need more details about the wires, are they the stock length or over the valve cover universals? If the wires are bigger tahn stock then you might have a problem putting them in the stock retaining clips. As for the waterpump sensor, you should be able to get it out. Mine broke at some point--the plastic broke cause I bumped it with a hammer or something, anyway I took the piece and crazzy glued it back together, and it has worked fine ever since. I would not remove the waterpump just for the sensor, if it already needs replacing then just break the rest of the plastic off and stick a socket or wrench on it, or vice grips, should be no problem.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
