which cam is better help!!!
Old Jan 15, 2007 | 07:48 PM
htowncamminz28's Avatar
Thumbs up which cam is better help!!!
which cam is better help!!! i had the cc306 and is a badass cam!!!but i did have heads before but now im starting from scratch.so far i have a slp exhaust,k&n cai,no cat,ported throttle body.i will have headers and a 2800 stall pretty soon and ofcourse 1.6 roller rockers and duel springs. so what u guys thing should i get the cc306,cc503 or the gm847 !!! which cam is bigger!!!better with stock heads for now?????thx yall
Old Jan 15, 2007 | 07:56 PM
seawolf06's Avatar
Cam Specs
I know some people run the CC306 and GM847 on stock heads, I don't know if I would. If you don't have money to do both, maybe you can do it for now and then get heads later so you don't have to do the cam swap twice. What springs do you have? Why not get a custom cam and heads all at once? Will be a much better setup.
Old Jan 15, 2007 | 08:04 PM
yeah u right but i wont have heads for another 6moths but i want a cam install also a 100 shot wet kit
Old Jan 15, 2007 | 08:28 PM
onephatZ28's Avatar
If you are going to run NO2 I go with the cc503
Old Jan 15, 2007 | 08:29 PM
seawolf06's Avatar
GM847 is old technology, so out of those, considering you're definitely going to get heads in a few months, get the CC306. You can check out the xfi cams from comp or the lunati voodoo cams, but I'd get a professional to setup your valvetrain since they're pretty agressive.
Old Jan 15, 2007 | 08:44 PM
and which one makes more raw power the cc3056 or the cc503 with and with out a tune?man thx guys for ur time!!!!
Old Jan 15, 2007 | 08:46 PM
seawolf06's Avatar
More duration and more lift usually makes more power if you can get it tuned right.
Old Jan 15, 2007 | 08:47 PM
onephatZ28's Avatar
My buddy made 388rwh with a cc503
seawolf06's Avatar
With stock heads?
yeah im thinking of going back to a cc306
Old Jan 15, 2007 | 08:49 PM
seawolf06's Avatar
What springs?
Old Jan 15, 2007 | 09:00 PM
reamo04's Avatar
get the comp XFI 466
Old Jan 15, 2007 | 09:09 PM
onephatZ28's Avatar
Originally Posted by seawolf06
With stock heads?
The AFR's 195 heads
seawolf06's Avatar
Ok, that makes more sense.
Old Jan 16, 2007 | 08:46 AM
2000GTP's Avatar
Of those 3, I would probably go with the CC503 on stock heads.
