Cyl. Head steampipe hardline alternative?
Old Jan 13, 2007 | 03:18 AM
TransAm396's Avatar
I want to get rid of the hardlines that connect each head(in the back) up to the front..I saw something on ebay where they used braided hose instead of the pipe and it looked good. Is there anyway I could do this? Maybe by having fittings put into the heads and running the hose from there?? Any ideas...?
Old Jan 13, 2007 | 08:14 AM
mdacton's Avatar
yeah it can be done
Old Jan 13, 2007 | 10:29 AM
TransAm396's Avatar
little more detail??
Old Jan 13, 2007 | 12:24 PM
87lt1rx7's Avatar
I second this request. A friend of mine is quite creative and wanted to do a setup using braided stainless some setup of AN fittings. anyone have any attempts or ideas?
Old Jan 13, 2007 | 03:13 PM
All you need is an adapter from the theads in the back of the head to the -AN size line you want to run.
Old Jan 13, 2007 | 05:14 PM
97s10ondubs's Avatar
The threads on the back of my heads were stripped, so i drilled and retapped them at a size bigger NPT pipe thread. I put a 90 degree on the driver head, and a T at the passenger head, and ran rubber radiator hose.
Old Jan 13, 2007 | 06:40 PM
LenT1's Avatar
If you do a search on here you will find a large thread discussing this. It can be done you just need to find the right threaded elbow for the an lines to plug in to the heads.
Old Jan 13, 2007 | 06:44 PM
TransAm396's Avatar
anyone have the sizes that can be used?
Old Jan 13, 2007 | 06:58 PM
mdacton's Avatar
just tap them out to a pipe thread and get the right adapter either a 4 or a 6 will work fine. if you are trying to srew a fiiting in the stock threads it wont work...the pipe thread seal on itself with tapered threads
like the guy said if you search you will find what you need, there was a lot of disc. on this topic
Red97LT1
Mar 1, 2015 05:08 PM
Gtpguy
Jan 26, 2015 04:50 PM
HectorM52
Jan 16, 2015 10:21 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
