Is the smog pump necessary??
Old Jan 17, 2007 | 04:01 PM
live4therush's Avatar
I'm swapping engines into a different camaro, and in the process i found that the setup for the smog system i have is a pain in the a$$. What will happen if i take the smog pump off and block the holes that go into the headers and the air intake where the lines run into them. Is this a possible thing to do or will i have troubles with the car afterwards. All O2 sensors are goin to be left on. Does anyone have any clue about this, let me know. thanks.
Old Jan 17, 2007 | 04:03 PM
camarodude8703's Avatar
i took my pump off when i did my long tubes headers, i had the pump tuned out of the computer and it didn't mess up any thing...
Old Jan 17, 2007 | 04:09 PM
how much did it cost to re-tune your computer? and where did you get it done at?
Old Jan 17, 2007 | 05:42 PM
2000GTP's Avatar
A mail order tune can run up to 150 bucks or more for a full PCM tune. A tuner may be able to do a specific code deletion for cheaper then a full tune though. Aside from that, removing the AIR pump won't have any ill effects on your car.
Old Jan 17, 2007 | 07:59 PM
SS RRR's Avatar
If the catyletic converter(s) are going to be left on the car you may eventually clog them w/out an air pump.
alphaauto
Jan 23, 2015 07:42 AM
Timberwolf
Aug 9, 2002 11:24 AM
Dark Angel
Aug 8, 2002 08:43 AM
Mister Will
Aug 5, 2002 10:23 AM
