a flutter i cant get rid of
Old Jan 15, 2007 | 04:33 AM
madlt1's Avatar
I have a 96Z I have a flutter while im driving a constant speed but does not do it while acelerating. If i let off the gas it almost quits then it will start ideling fine. it does the same if you stall it up slightly. ANY IDEAS?
Old Jan 15, 2007 | 05:09 AM
Guest47904's Avatar
Guest
Will it do it if it's sitting in the driveway or does it only do it under load?
Old Jan 15, 2007 | 05:28 AM
madlt1's Avatar
just under load
Old Jan 15, 2007 | 11:20 AM
DAdkins23's Avatar
Check your fuel pressure to start with.....Have someone give it gas while you check it.... have them give it consistent gas like you would be if driving at a constant speed, and see if it drops.....
---- Dax
Old Jan 15, 2007 | 12:45 PM
TobyZ28's Avatar
A4 / M6? Is that anytime at load or only at a small load on the hwy for instance?
Might wanna post some info about the car in your sig.
Old Jan 15, 2007 | 03:56 PM
Guest47904's Avatar
Guest
Try disconnecting the EGR and plug the vacuum line and see what happens.
Old Jan 16, 2007 | 02:18 PM
madlt1's Avatar
I have noticed my fuel pump makin a buzzin noise i will check the fuel pressure first.
Old Jan 16, 2007 | 03:01 PM
TobyZ28's Avatar
http://web.camaross.com/forums/showthread.php?t=496292
Help me help you...
Old Jan 16, 2007 | 08:39 PM
key3's Avatar
I work with him and its a automatic. I have a fuel pressure gauge I will let him use.
Aug 5, 2015 08:35 AM
beltrunner
12
Jul 15, 2015 08:39 PM
buggy323
Jul 1, 2015 04:37 PM
Apr 16, 2015 09:57 AM
armedtrigger
Feb 24, 2015 08:30 PM
