Oil Recommendation..??
Old Jan 11, 2007 | 10:36 PM
Sdimein's Avatar
Just wondering what type of oil you guys would recommend using with a 135K 96' motor, stock bottom end, LT4 kit, intake, tunned..
Jlo's Avatar
Jlo
Mobil 1.
Old Jan 11, 2007 | 10:50 PM
Sdimein's Avatar
10w30.. or what ??? btw im located on the georgia coast.. winter feels like summer and summer feels like hell..
Old Jan 11, 2007 | 11:16 PM
wasntme's Avatar
SYTHETIC Mobil 1, 10w-30 "extended performance"
every 2500 miles for me.
Old Jan 11, 2007 | 11:27 PM
LT1 POWR's Avatar
Damn, you know that stuff can go 15,000 miles before an oil change right. I would never go 15,000 but even 6,000 would save you about $50 every oil change.
I use Mobil 1 0w-40 right now, but would like to switch to German Castrol 0w-30 if I can find someone who carries it. I hear the German Castrol is the best for LT1's. The oil I'm using now is probably the second best oil next to the GC.
Old Jan 12, 2007 | 12:06 AM
porksoda's Avatar
The GERMAN Castrol only comes in 0w-30
Old Jan 12, 2007 | 01:10 AM
LT1 POWR's Avatar
Yeah, thats what i meant.
Old Jan 12, 2007 | 07:51 AM
SMW's Avatar
SMW
Hotlanta - Mobil 1/10w30....
Old Jan 12, 2007 | 08:05 AM
rje's Avatar
rje
Amsoil 0w30, the best there is.
Old Jan 12, 2007 | 10:35 AM
micfly83's Avatar
I was going to put in Valvoline Max Life (or whatever it is) 20W50
Aren't you supposed to put in a heavier weight in higher mileage engines to prevent leaks from synthetics and the lower weight oils
At least thats what the autozone guy told me
Old Jan 12, 2007 | 11:19 AM
2000GTP's Avatar
I like to dump the Mobil 1 synthetic in mine as well. Its not cheap, but still cheaper then 5 quarts of Royal Purple.
Old Jan 12, 2007 | 11:30 AM
moparman's Avatar
Autozone is the only place I know of that has the German Castrol.
Old Jan 12, 2007 | 01:05 PM
96capricemgr's Avatar
Might I suggest you edit the question to ask "and why" because you are getting info not backed up by fact. I am not saying they are not posting the facts I am saying with certainty that several of these guys have ZERO data on which to backup their choices validity.
From what I am reading LT1 Power, porksoda and moparman have done some research, the others seem to be more likely relying on marketing.
Old Jan 12, 2007 | 01:17 PM
EnerjetF67's Avatar
I run Red Line 10w30 in Winter and 20w50 in summer.
Typically I change it at 10 to 12,000 miles.
I change the filter every 5 to 6000 miles, but 90% of my 120mile round trip to work each day is freeway at steady speed.
Not cheap at $8/qt., but I see it as cheap engine insurance.
Old Jan 12, 2007 | 01:23 PM
always faster's Avatar
Go read on this forums there:
http://theoildrop.server101.com/forums/ubbthreads.php
For a lt1 the 3 best choice base on oil analysis are:
-Castrol German synthec 0w30
-Amsoil European synthec 5w40
-Mobil 1 synthec 0w40
Since in Canada im unable to find some castrol, i use the amsoil one.
