Pushrod Length for Trick Flow Heads
Old Jan 15, 2007 | 09:31 AM
sker66's Avatar
I'm building a 383 stroker using the LT1 Trick Flow Heads with the Crane Gold stock LT4 1.6 ratio roller rockers.
Does anyone have experience with what Pushrod Lenght will work with this package??
Thanks in advance.......G
Old Jan 15, 2007 | 09:45 AM
Will you be milling the TF heads, to reduce the 62cc combustion chamber volume? That obvioulsy would affect pushrod length. In any case, its always a good idea to measure the actual required length.
Old Jan 15, 2007 | 10:33 AM
Javier97Z28's Avatar
Moderator
Measure it once assembled with an adjustable pushrod. Deck height, gasket thickness, and head milling all come in to play.
Old Jan 15, 2007 | 11:53 AM
Z-RATED94's Avatar
As stated, measuring is the only way to know "FOR SURE" dude. Just recently found out myself and had to buy some new shorter pushrods.
oldschool
Feb 9, 2016 09:21 PM
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
