hotcam question
Old Jan 18, 2007 | 10:10 PM
ajlew9428's Avatar
hotcam question
Is it possible to buy, or fab a hotcam w/ the pre 95 smaller pin drive for my 94?
Old Jan 18, 2007 | 10:40 PM
VK's Avatar
VK
When you get the LT4 hotcam, the dowlpin is the "long" version. Messure the length of the dowlpin that is on your stock cam, if shorter then remove difference with a grinding tool. Its ok if its not perfect to the mm, as long as its not ANY longer then stock you will be fine. U just don't want the new dowlpin to push into the back of the optispark cuz the pin is extra long.
Old Jan 18, 2007 | 10:44 PM
camarodude8703's Avatar
when i did the LT4 hot cam on my friends 94 T.A. i just measured and then used a dremel to cut off the rest... good luck
Old Jan 19, 2007 | 12:11 PM
ajlew9428's Avatar
sounds good. Thanks guys
Old Jan 19, 2007 | 12:47 PM
maybe2fast's Avatar
can you buy a seperate dowel from GM for the hotcam?
Old Jan 19, 2007 | 04:16 PM
VK's Avatar
VK
I don't think so.. try talking to a local machine shop(?)
Old Jan 19, 2007 | 06:01 PM
Kory 88 Iroc Lt-1's Avatar
Why grind it off. I just used a small hammer and lightly tapped it in until it was the same length as the stock cam. If you want to sell the cam to some one down the road who happens to have a 95 you can push the pin back out with a punch and a hammer ( the dowel pin goes all the way through)
hope this helps.
Kory
jasonduaine
Mar 7, 2015 09:44 AM
InfernalVortex
Jan 17, 2015 09:35 AM
WildRidez
Jan 16, 2015 03:10 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
