Broken EX612 Valve spring.
Old Jan 14, 2007 | 09:13 AM
jchevy's Avatar
Driving my car friday night a valve spring decided to break. Broke into about 3 peices. Spring came completely off the valve so it im guessing it probably made contact with the piston.
Looks like I have all the peices so thats a good sign, hopefully there is no metal elswhere in the motor. Is there any chance the valve isnt bent or messed up. Im hoping it maybe ok if the piston was hitting it flat at low RPM and it was moving freely with no rocker or spring on it. I think Im going to throw another spring on it and see if that cylinder will hold compression.
Old Jan 14, 2007 | 09:35 AM
Dave89IROC's Avatar
pull the valve closed by hand and lossen the other rocker, put some air in the cylinder, and see if any air comes out the intake/exhaust, if none comes out, your good(you will get some out the oil filler/crankcase=normal), if air does come out the exhaust/intake, then you have a bent valve
Old Jan 14, 2007 | 09:37 AM
jchevy's Avatar
Ok I will try that. It was the intake spring that broke.
Old Jan 14, 2007 | 02:36 PM
jchevy's Avatar
Im guessing the valve is probably bent. I lossened the exhaust rocker and pulled the intake valve up. Will not hold any pressure at all and there is a good bit of wind blowing out of the throttle body.
So now what are the chances that the head is messed up?
Old Jan 14, 2007 | 02:55 PM
Dave89IROC's Avatar
possible, but unlikely
Old Jan 16, 2007 | 07:13 PM
jchevy's Avatar
Got the head pulled today, Valve is bent and the guide is cracked. How much can I expect to pay a machine shop to replace it?
Old Jan 16, 2007 | 09:27 PM
Dave89IROC's Avatar
1 guide, 1 valve, shouldn't be too much
Old Jan 17, 2007 | 08:34 AM
Z-RATED94's Avatar
Do a search, might be your not the only one with problems with those springs. I could be wrong and it's not the 612s, but if it were me trashing a spring I would wonder if it's going to happen again.
Old Jan 17, 2007 | 05:08 PM
jchevy's Avatar
Yeah, I will be replacing all the valve springs with something differnet. Probably the comp bee hives.
Old Jan 17, 2007 | 07:47 PM
Bersaglieri's Avatar
Do what Lloyd is doing and move up to the crane 10308 spring kit. .600 lift and up to 7000rpm's for under $150.
-Dustin-
Old Jan 18, 2007 | 05:29 AM
NightTrain66's Avatar
If you want another 612 springs, just send me a PM.
I have a few sets here and you can have 1 for free.
I would REALLY sugguest going with the Comp 26918-16, 795-16 and 611-16 set up. This will be about $275-300. These will clear the almost any rocker and have even more retainer/rocker clearance than the 612 springs.
The Crane 10308-1 dbl spring, retainer and lock kit will also be a BIG upgrade over what you have. These will clear the Comp Pro Mag rockers but some of the "wide body" rockers have retainer/rocker contact problems. These are $150 or so thru Jegs/Summit.
Old Jan 18, 2007 | 01:21 PM
SStrokerAce's Avatar
-Dustin-
Well not really you have to shim them up enough to work that they aren't going to get .600" lift in there. The Crane kit is the standard on the LE1 heads.
Lloyd is right, the beehive upgrade is about that price and the best bet out there. That's why it's the standard on everything above the LE1 heads.
Bret
Old Jan 18, 2007 | 05:07 PM
jchevy's Avatar
I decided to go with the comp 26918-16, 795-16 and 611-16 set up.
Will I need to shim these springs?
94Form
Jul 17, 2015 10:56 PM
GT what?
Jul 14, 2015 10:17 PM
Fastbird93
Jul 11, 2015 04:37 PM
Red_94Formula
Jan 22, 2015 12:17 AM
