Strange oil leak
Old Jan 18, 2007 | 06:09 PM
gex598's Avatar
Strange oil leak
I installed my new 383 today and put on the milidon pan. I primed the motor before the install and found a oil leak! Its coming from one of the oil pan rail bolts near the oil filter. The bolt is snug and its clearly coming from the bolt not of of the side of the pan. The motor only had 1.5 quarts of oil in it as well. Is it possible for the motor to leak thru a oil pan bolt?
Old Mar 22, 2007 | 07:41 AM
gex598's Avatar
I found the leak, when I clearanced the block it looks like I took alot off the oil pan rail and didnt leave much room between bolt and rail. I put some copper RTV on the pan gasket and no more leak.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
