car wont start,need ideas quick
Old Jan 15, 2007 | 01:01 PM
beeker82's Avatar
about 2 months ago I replaced the msd coil with a stocker,car has ben running fine up until a few weeks ago,it has power and will crank but wont turn over,last time it did it I gave it just a little gas and it eventually started,now nothing, it runs fine when I get it started, I can hear the fuel pump prime and the injectors tick,I dont know what else it could be,any ideas?
Old Jan 15, 2007 | 02:14 PM
beeker82's Avatar
anyone?
Old Jan 15, 2007 | 02:15 PM
camarodude8703's Avatar
Just cause you can hear it prime doesn't mean it's working perfect..
check the pressure on the fuel rail..
Old Jan 15, 2007 | 02:19 PM
beeker82's Avatar
I dont have access to a fuel pressure guage
Old Jan 15, 2007 | 02:43 PM
Guest47904's Avatar
Guest
You can do a few easy things. First relieve any pressure in the schrader valve. Now cycle power on then off about 5 or 6 times. Now check the schrader valve again to see if pressure came back.
Next check a few plugs for spark. Be sure to check a back plug as well. While you have the plug out either check compression, do a leak down test or simply hold your finger over the plug hole while cranking to see if it shoots air out.
If you have spark, try squirting fuel in the intake while someone cranks it over. If that doesn't do it, jump the upper right 2 pins pins on the ALDL to retrieve the DTC's.
Old Jan 15, 2007 | 03:40 PM
beeker82's Avatar
we checked the shrader valve and recycled it,still squirts out gas
Old Jan 15, 2007 | 03:51 PM
Guest47904's Avatar
Guest
Did you totally relieve the pressure before cycling power?
Old Jan 15, 2007 | 03:56 PM
beeker82's Avatar
yep
Old Jan 15, 2007 | 03:59 PM
Guest47904's Avatar
Guest
Ok well we'll mark that off the list as done.
Next
97SSdude
Dec 31, 2014 07:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
Absolute Z28
Jul 19, 2002 02:21 PM
