quick ses question
Old Jan 14, 2007 | 05:46 PM
ajlew9428's Avatar
quick ses question
I have 160 thermo. and have an ses light, so the fans are on constantly, and the car never gets over 170. Even when stopped. Is this preventing me from running in open loop? where my sensors pickup, and register to determine air/fuel, etc?
Old Jan 14, 2007 | 07:38 PM
OBE1 95Z28's Avatar
Get your SES code read to understand what's going on. You system starts out in open loop and goes to closed loop after meeting several conditions include a mininum coolant temperature.
Old Jan 14, 2007 | 09:55 PM
The enable coolant temp for entering closed loop seems to be a variable value, within the range of 120-140degF, so you don't have a problem in that respect.
But why continue to drive with an SES light?
Old Jan 15, 2007 | 08:56 AM
ajlew9428's Avatar
the ses is there b/c I recently deleted the egr
Old Jan 15, 2007 | 10:28 AM
Are you sure? Which EGR code are you getting? If its for the solenoid, all you need is a resistor. There's also a spoof if its for "low EGR flow". Wy not eliminate the codes and let the fans run the way they are supposed to?
Old Jan 15, 2007 | 07:34 PM
ajlew9428's Avatar
I just recently had all the mods in my sig put on,except cai, and exhaust, and had the air, egr blocked off. I had new opti, fuel pump, wp, plugs, etc, and had my installer tune it a little. His name was mike harris( fastest naturally aspirated lt1 b body impala) and he told me I need to get a mail order tune, and the code should be from the egr. So Im guessing its that, b/c car runs amazing. Ill still get it scanned to make sure before I get it tuned
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
96z
Aug 2, 2002 09:00 PM
