Coolant pipe
Old Jan 15, 2007 | 12:52 PM
93BlackTA's Avatar
Coolant pipe
Anyone have the Gm part number for the coolant pipe that connects on the back of the two cylinder heads and comes towards the front of the engine? Anyone know where i can get one or can i just plug the holes? If i need to replace it then part numbers for the bolts also please....Thanks....
Old Jan 15, 2007 | 01:18 PM
camarodude8703's Avatar
DO NOT PLUG them.. bad idea.. you can get them a dealer.. there not that bad they come with the bolts... i payed 38 for mine.. just call the dealer ask for parts and explain the part to them they should e able to help..
Old Jan 15, 2007 | 01:51 PM
Bookmark Shoebox's website:
http://shbox.com/1/Parts.htm
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
http://shbox.com/1/4th_gen_tech1.html
You also need seals.
1995-1997 steam pipe behind heads, incl bolts and seals - 12556260 - $24.91
1993-1997 coolant steam pipe seals - 10108689 - $3.00
1993-1997 coolant steam pipe bolts - 12552974 - $3.07
Old Jan 15, 2007 | 02:03 PM
93BlackTA's Avatar
Whats the difference in the 93-94 steam pipe and the 95-97? Thanks
Old Jan 15, 2007 | 03:24 PM
The early pipe contiunues with a rubber hose to the radiator. The late pipe stops to elbow into the throttle body.
Old Jan 18, 2007 | 09:27 PM
blackpixi7's Avatar
For a nicer look, you can get two 1/4" to 6AN fittings, some 6AN lines, a tee fitting and have a nice braided line setup that cleans up the engine bay a little.
Old Jan 27, 2007 | 09:27 PM
93BlackTA's Avatar
Anyone have some pics of this? I like this idea....
blac94Z
Feb 15, 2021 09:43 PM
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
Latronaxe
Jun 10, 2015 02:08 PM
Queens94z28
Mar 23, 2015 08:06 AM
