Camaro engine swap
I have a 305 in a RS now, so what would I have to swap besides the engine to get it to pass smog? A shop is doing the work, so they won't warranty the labor on any parts that I supply.
Can a 350 engine be modified to be as high in hp and torque as a LT1?
It would be much easier to use the 350 to pass smog.
u could probably do it with the L98 though
dont u guys have to pass like the BAR inspection or something in california?
The 350 would be a 1991 so it would have fuel injection, not a carb. Are a new fuel injection, ecm and headers be something I could add after the install and still have it pass smog in CA.
If the parts you buy have CARB stickers, then you should be good to go in California.
Jul 4, 2005 05:00 PM
