Difference in cam from 350-383???
Old Jan 17, 2007 | 11:45 PM
Meen95z's Avatar
Is there a difference or a change need to be made in going from a lt1 355 to a 383 in the camshaft? Someone brought up a reduced circle base? Can someone shed some light on this issue? Thanks
Old Jan 18, 2007 | 01:51 PM
gixxer92's Avatar
From my experiences with two motors and two eagle assemblies they clear w/o needing a smaller base circle cam on the hydralic rollers.
Edit - both of my motors are 383's
A lot of it depends on what rods your using with your stroker and weather or not the throws will clear the cam lobes
Old Jan 18, 2007 | 02:29 PM
1racerdude's Avatar
You will need a smaller base circle to clear the stroke change. Something in the neighborhood of .990-.950. If ya get the right stroker rods the clearance on the block is minimal.
Old Jan 18, 2007 | 06:55 PM
Meen95z's Avatar
I want to get Scat Forged I beam 5.7 rods.. Can I still use a regular 306 or 468xfi cam?
Old Jan 19, 2007 | 03:21 PM
1racerdude's Avatar
Ask your cam manufacturer.
There is no drawback to a small base circle cam.
jj_burchiel
Mar 5, 2015 07:05 AM
InfernalVortex
Jan 17, 2015 09:35 AM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Dec 20, 2014 09:11 PM
