When would a Guy need upgraded rod bolts?
Old Jan 23, 2007 | 12:59 PM
remaxracer45's Avatar
Cool When would a Guy need upgraded rod bolts?
Looking to freshen a 96 low miles LT1 want to put forged pistons as it needs to be bored do to a poor ring install. So I thought get forged pistons, clevett bearings, high end rings and put my XE cam GM performance timing set and my LE2 heads and go looking at 4 something to the rear wheels in the end. If I need bolts where do I go and cost?
thanks
GO BEARS!
Old Jan 23, 2007 | 01:06 PM
MaxLean's Avatar
It's always a good idea to upgrade the bolts in a performance application. It's cheep insurance. I'd recommend ARP, of course.
Scott
Old Jan 23, 2007 | 01:08 PM
KGRESOCK's Avatar
Scott
DITTO
Old Jan 23, 2007 | 01:13 PM
2000GTP's Avatar
If you already have it apart, I would definitely upgrade them, especially considering that a set of ARPs will not cost an arm and leg.
Old Jan 23, 2007 | 01:18 PM
Javier97Z28's Avatar
Moderator
Just replace 'em w/ a forged set, the cost diff isn't that great compared to a Scat forged I-beam or something along those lines.
Old Jan 23, 2007 | 01:45 PM
Critter's Avatar
upgrade the rod bolts!!!! i wish i would have. kinda like extra insurance when your spinning past 6200.
Old Jan 23, 2007 | 03:36 PM
Z28SORR's Avatar
I would upgrade also, but this is really just a comfort thing. I don't think it's required, the stock bolts are really quite good.
It's funny when you think about it. I've purchased many new chevys over the years and driven the **** out of them, rev'ing to 6500 or 7000rpm's, missing an occasional shift and buring the tach., and seldom had a problem. Yet it comes time to rebuild and the engine has to have the best of everything!!!
Old Jan 23, 2007 | 07:59 PM
seawolf06's Avatar
Make sure if you just get new bolts that you have the rods resized by a machine shop.
Old Jan 23, 2007 | 10:19 PM
what do you mean by resizing the rods?
Old Jan 23, 2007 | 10:23 PM
seawolf06's Avatar
As I was told, when you press the new rod bolts in, they cause the rod end to become egg-shaped. You need to resize them to correct that deformation.
Old Jan 23, 2007 | 10:37 PM
is that spendy?
Old Jan 23, 2007 | 10:51 PM
seawolf06's Avatar
It was free for me with my full race prepped block and bottom end. That was a bit pricey, but it included a lot. I recommend Wall 2 Wall racing for anyone in the Louisiana area.
Old Jan 25, 2007 | 10:32 PM
nosfed's Avatar
Seriously, look into a set of Scat I beams. By the time you buy the rod bolts and have them installed and resized, you are real close to the price of a set of new rods. They may not be 4340 but they are better than the stockers, by a good margin.
Old Jan 25, 2007 | 10:54 PM
rskrause's Avatar
Moderator
That's correct. You can't just substitute new bolts.
Rich
Jazsun
Dec 29, 2014 12:14 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Red97LT1
Aug 7, 2002 05:45 PM
