cam duration @ .050(math)=adv. duration
Old Jan 22, 2007 | 05:52 PM
KY95Z28's Avatar
I have searched through it seems like thousands of threads here, google, and everywhere else trying to figure out if you can get the ADV. Duration when you only have the duration at .050. I have the cam card with all the info but it is all list in terms of .050.
I need this information to finish calculating the DCR for my new motor.
Can this even be done, or will I have to have other information.
Any help is appreciated.
Thanks,
Nick
Old Jan 22, 2007 | 05:53 PM
speed_demon24's Avatar
No way of knowing unless you know what lobes you ahve on the cam.
Old Jan 22, 2007 | 06:53 PM
97bowtie's Avatar
Ditto.
Old Jan 22, 2007 | 07:15 PM
RE AND CHERYL's Avatar
The reason duration at .050" is usually used is because there are several ways of measuring where duration starts. Cam maunfacturers use .003", .006" and I've even heard the phrase "precevable movement" used. Using the different techniques you can have noticably different "advertised durations for the same cam.
Old Jan 22, 2007 | 07:21 PM
KY95Z28's Avatar
I have some lobe information on the carda(lobe lift/lobe area). I just need to get ahold of Allen @ Futral to get the specs.
Thanks for the info.
blkWidow
Apr 21, 2015 01:56 PM
blac94Z
Exhaust System
Feb 17, 2015 04:14 PM
Cam's maro
Jan 30, 2015 09:21 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Timberwolf
Oct 10, 2002 05:25 PM
