Intake Elbow
Old Jan 21, 2007 | 10:35 PM
theratdude64's Avatar
Intake Elbow
My stupid intake elbow ripped, but I already got replacement. My question is can I delete that donkey dong air silencer thing very easy? Just take it off and plug the hole kind of thing or is there more to it than that?
Old Jan 21, 2007 | 10:52 PM
95LT1conv's Avatar
just take it off and plug the hole
Old Jan 22, 2007 | 07:11 AM
Next time get a 1LE elbow. It does not have the silencer tube.
Old Jan 22, 2007 | 08:30 AM
Ahh up until I got my car I didnt even know the silencer existed, now I know what the 1LE is good for heh. I got this one for $20 and it was an emergency fix, so I'll get a 1LE sometime. Thanks
Old Jan 22, 2007 | 09:46 AM
94jetpilot's Avatar
Cool silencer option.
this is probably gonna sound cheezy,but hey it works! i took mine off, and installed a cap of a flat black spray can up underneath the silencer hole and screwed it on each side to keep it from falling off, just squeeze it on on voila!,be careful though if you desire another set up,there is alot of suction in that area,so you dont want to have anything sucked in to the "jet zone",good luck!
Old Jan 22, 2007 | 09:57 AM
2000GTP's Avatar
From what I hear, the 1LE elbow is thicker rubber as well making it less prone to tearing.
Old Jan 22, 2007 | 10:45 PM
Ya I found something last night that looks like it would be a good plug, but i wanna make dammnnn sure it cant get sucked in or something
Old Jan 22, 2007 | 10:47 PM
Z95m6's Avatar
Or just as importantly, it doesn't leak air.
Old Jan 22, 2007 | 11:31 PM
Ya, that too :-p
Old Jan 22, 2007 | 11:57 PM
mcalus's Avatar
Mine has a little rip in it...would that effect my performance any?
Old Jan 23, 2007 | 12:05 AM
Sources point to... That sucks. heh. I'm surprized, my idle wasnt messed up at all or anything but there was a big tear around the edge on mine
Old Jan 23, 2007 | 12:11 AM
Z95m6's Avatar
Not on a 93 car because your car is a speed density car. You may be sucking in dirty air though which is never good.
Old Jan 23, 2007 | 12:14 AM
mcalus's Avatar
What does that mean..."speed density?"
Old Jan 23, 2007 | 12:20 AM
Z95m6's Avatar
94+ cars have a (MAF) or Mass Air Flow sensor to read how much air is coming into the motor. The PCM then adjusts the fuel based off of these readings. So if you have a tear and are sucking in air after the MAF its going to hurt performance because unmetered air is getting into the engine. On a 93 the computer reads several different sensors to get an estimation of how much air flow is going into the motor and adjusts accordingly.
Old Jan 23, 2007 | 07:00 AM
Dirty, unfiltered air is not a performance enhancer.
