96 Smog Pump can I do without it ?
Old Jan 19, 2007 | 01:57 PM
2tight's Avatar
I have a 96 I'm doing plugs and wires right now and I'm looking to order Pacesetter Headers can I get the ones Without Emissions Fittings if I do away with Smog pump ? Can this been done and still pass emissions testing?
Old Jan 19, 2007 | 02:15 PM
2000GTP's Avatar
If you get the ones without emissions fittings, be aware that they do not have the EGR fitting as well so you will have to remove both the EGR and AIR systems. You will need some EGR blockoff plates and PCM tuning to avoid the SES light once those systems are taken out.
Old Jan 19, 2007 | 02:24 PM
2tight's Avatar
Will it still run ok before I have it tuned or I'm I going to have it get it tuned up at the sametime? Man you can drop some $$$ quick on these car's. What would you do.
Old Jan 19, 2007 | 02:27 PM
2000GTP's Avatar
If you remove the air pump, it will still run okay but you will have the obvious check engine light illuminated on the gauge cluster. Personally, I would just wait until you are completely sure if you want to install headers and what type you plan to install. Removing the air pump will not yield you any performance gain other then shedding a few pounds off of your car.
Old Jan 19, 2007 | 02:40 PM
Javier97Z28's Avatar
Moderator
If you're keeping cat's, keep the AIR pump.
alphaauto
Jan 23, 2015 07:42 AM
Timberwolf
Aug 9, 2002 11:24 AM
Dark Angel
Aug 8, 2002 08:43 AM
Mister Will
Aug 5, 2002 10:23 AM
