Dynaspark Gen 3 Users?
Old Jan 20, 2007 | 02:39 PM
WhiteLT1z's Avatar
Has anyone used this yet with an LTCC setup?? I did a search but the only post i found on the Gen III was somebody saying it was coming out soon, and that was a while back.
So if anyone that is using it or has used it can give me some info, and let me know if it was worth the cash i would be very thankful.
It looks great, thats for sure.
Old Jan 21, 2007 | 02:40 PM
WhiteLT1z's Avatar
Hmm, I found this on LS1tech:
The Gen 3 distributor carries over all the benefits from the standard dynaspark including, sealed integral wiring harness, sealed press fit bearing with a 360 degree retention ring, improved optical sensor cooling for ideal operation in the higher rpms, and so on...
The Gen 3 is fitted with a recessed 6061 extrude hone billet aluminum cap and housing to allow heat to dissipate from the distributor with ease. The inside of the cap is finished with an EMI (electromagnetic impulse) reduced coating to prevent intereference with your optical pickup at high rpms. The reluctor wheel mount and backing plates are black oxide coated to prevent corrossion.
The billet cap is equipped with our triple sealing technique to eliminate leakage. The cap is secured with proprietary stainless steel security fasteners to garuntee our work. All hardware inside the gen 3 is stainless steel. Each unit is assembled by hand in our shop by trained technicians. After the final assembly the unit is then tested on our machines to garuntee its operation.
The Gen 3 has proven to be a bullet proof design in our beta testing and we are confident in its performance. Our optical sensor is used in Formula 1 racing and tested to be accurate to 10,000 rpms. Our bearing is manufactured by NTN and rated to 13,000 rpms. With the Gen 3, your distributor will no longer be a limitation---
Our graphic designer has taken all of the photos for the website. Subsequently, we have nothing at this moment. We will get a digital camera and hopefully have pictures for you by the end of the day. Keep in mind that the Gen 3 also carriers a 12 month warranty from the date of purchase. If you have any further questions regarding the Gen 3 please don't hesitate to ask, we would be happy to explain things further. Thank you for your interest, we look forward to providing you with the very best.
Sincerely,
Dynaspark Crew
Sounds pretty good, just wondering how it runs..
Old Jan 22, 2007 | 04:22 PM
WhiteLT1z's Avatar
Anyone?
Old Jan 24, 2007 | 11:20 PM
WhiteLT1z's Avatar
ttt, lol.
Victor Lamb
Aug 26, 2017 02:52 PM
QuickSilver02
Apr 7, 2015 11:12 AM
maybe2fast
Feb 5, 2015 05:14 AM
Jlo
Feb 3, 2015 09:41 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
