HP guess for headers and rockers?
Old Jan 19, 2007 | 08:47 AM
Gripenfelter's Avatar
Having a debate with someone in my office.
Figure a 1993 Z28 with decent compression.
Mac 1 5/8" shorties.
1.6 rockers.
LT4 valve springs.
Callaway Honker CAI.
Cat replaced with straight pipe.
2.5" cutout on stock intermediate pipe right before the axle.
Fastchip stage II chip to maximize above mods.
What would you ballpark the horsepower to be at with the above mods? At the motor not RWHP.
Old Jan 19, 2007 | 08:59 AM
Z-RATED94's Avatar
My guess would be 315hp at the flywheel. What's your guess, your no rookie?
Old Jan 19, 2007 | 09:14 AM
mdacton's Avatar
315 flywheel sounds about right
Old Jan 19, 2007 | 09:15 AM
BUBBA's Avatar
Ditto on 315.
Old Jan 19, 2007 | 09:25 AM
97bowtie's Avatar
I'd expect that setup to put down around 290-295 rwhp, so I'd say the flywheel HP would be closer to 335.
Old Jan 19, 2007 | 10:37 AM
I had said between 320-330 hp. The 93s also respond better to those mods.
I remember when I had those exact mods I was running 13.3s at the track. Can't remember the mph. 106?
My coworker was WAY off. He figured 350 hp.
Old Jan 19, 2007 | 10:43 AM
BUBBA's Avatar
335---could be. One can only take a WAG. Stock, the RWHP would probably be around 335-340, thereabouts if everything is working well. Then one would need to consider the contributions of the mods ----and whether the A/F numbers were maximized, etc. And...you really can't take each mod separately, but consider the combination and how each mod effects the other. E.g., the headers are 1 5/8, whereas with a 350 CID, 1 3/4 might work out better. Also, Dyno numbers can vary from machine to machine and one pull to another.
And...backing into the crank numbers from RWHP is also subject to WAGs.
It's pretty much a mystery.
Old Jan 19, 2007 | 11:43 AM
97bowtie's Avatar
My buddy's car with nearly that exact setup (minus a chip - he had the stock tune) put down 297 rwhp through a 6 speed, which is probably closer to 340 HP at the crank.
But yeah, this is all bench racing as there are too many variables involved. 315 to 345 is probably a good range.
Old Jan 19, 2007 | 01:21 PM
2000GTP's Avatar
I would guess it to be around 330-340ish as well.
Old Jan 19, 2007 | 04:35 PM
Chris 96 WS6's Avatar
290-295 at the wheels.
Old Jan 19, 2007 | 04:48 PM
Critter's Avatar
330 at the most
Midnight_Z
Feb 16, 2016 09:36 PM
oldschool
Feb 9, 2016 09:21 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Sauced
Apr 12, 2015 10:18 AM
