Anyone against putting 1.6 rockers on a high mileage LT1?
Old Jan 11, 2007 | 01:04 PM
Bow94z's Avatar
Just browsing through searchs and hearing som mixed opinions throughout some threads and 2 mechanics telling me the increased lift is too much on a 143K mile motor..
I really dont see any problems with this
just 1.6 rockers and LT4 springs...
Old Jan 11, 2007 | 03:22 PM
Pyrodawg's Avatar
I have a crane cams dual valve spring kit with titanium lockers and whatnot with comp cams pro mag SA 1.6s. They were put on around 125k miles or so and i have 136k on it now with no problems
Old Jan 11, 2007 | 03:51 PM
2000GTP's Avatar
I don't see why not, it would be a good time to address some other valve train components such as the springs and pushrods as well.
Old Jan 11, 2007 | 04:02 PM
ChevalierSS's Avatar
replace valve seals also. The only thing I think it could possibly hurt is the lifters.
Old Jan 11, 2007 | 04:25 PM
BUBBA's Avatar
As compared to what....installing on a low-milage car and not removing them when the clock hits 143K....
Old Jan 11, 2007 | 05:55 PM
sbca96's Avatar
hehe .. 143k is high miles?? Tell that to my 177k 95 Z28, 218k Impala and my
233k 93 Z28. And to think was was considering doing 1.6/springs to the 93!
Tom
Old Jan 11, 2007 | 06:45 PM
Bow94z's Avatar
Tom
ok you win
Old Jan 11, 2007 | 08:03 PM
speed_demon24's Avatar
If anything it would make your car more reliable, new valve stem seals + new springs.
Old Jan 11, 2007 | 08:09 PM
johnny3986's Avatar
What all is involved in putting in new seals? Can the heads remain on if you are careful?
Old Jan 11, 2007 | 08:51 PM
razor02097's Avatar
rings last a long time and so does the bottom end if not abused... TOO... much. Frequent oil changes maximize engine life. If the car still runs pretty strong and doesn't make strange noises then some new valve train components would definitly help. Most times on SBC its the top end that starts leaking and allowing oil passage into the cylinder. New valve seals springs, retainers, rockers, pushrods, lifters and a cam would freshen up the top end and probably free up some ponies to boot
Old Jan 11, 2007 | 09:50 PM
reamo04's Avatar
im not sure i would do a new cam on a 143k motor, it may not take it too well and you would more than likely spin a bearing before too long
Old Jan 11, 2007 | 09:52 PM
Bow94z's Avatar
Yea i understand that, im just talkin valve springs/1.6 rockers
Old Jan 11, 2007 | 09:55 PM
reamo04's Avatar
i'd probably do springs, rockers, pushrods, etc. EVERYTHING except cam
Old Jan 11, 2007 | 10:53 PM
Theres no reason to change the lifters/pushrods with s/a rockers and a stock cam.
Old Jan 11, 2007 | 11:13 PM
wasntme's Avatar
whats wrong with putting a bigger cam in a high milage motor. i have 158 on the clock in my 93 z28, but im going to go with a new forged bottom end to... that makes a differance.... correct?
