MSA 6A - At what point do you need it?
Old Jan 12, 2007 | 09:45 AM
user 647483's Avatar
I see a lot of people running MSD ignition systems.
But I'm not sure I understand what I would really gain from it.
(not saying it's not a good mod, just looking for more info)
Can anyone help me out here?
Here the marketing blurb I read when I searched for it
Originally Posted by MSD
MSD Ignition Systems produce hot multiple sparks that ensure complete combustion of air / fuel mixture, resulting in increased performance over stock.
  • Quicker throttle response
  • Smoothed out idle and starting
  • Reduced Spark plug fouling
  • Improved Fuel Economy
  • Helps Reduce Emissions
Edit: If this is in the wrong forum, please feel free to move it.
I am specifically looking for info related to ignitions on LT1s.
Old Jan 12, 2007 | 10:43 AM
It may do those things, but you may not notice anything at all on a stock car. Not really a must on a stock car. If you are heavily modded, it might be of more value.
Old Jan 12, 2007 | 10:52 AM
It's an H/C car, stock bottom end, auto, shifting at 6375.
Mods list -> http://www.cardomain.com/ride/2297151
Old Jan 12, 2007 | 11:04 AM
2000GTP's Avatar
A heads/cam car or forced induction platform with increased cylinder pressures can see some results from the hotter spark an aftermarket box provides.
Old Jan 12, 2007 | 11:44 AM
BUBBA's Avatar
The very first mod I did when I bought my 97SS. Whether or not you gain anything, I cannot say, but I wouldn't remove it for the world.JMHO
Old Jan 14, 2007 | 07:54 PM
OBE1 95Z28's Avatar
Buying a MSD 6AL gives you a rev limiter that cuts ignition at the rev set point rather than the stock PCM that cuts fuel, which could lead to a lean condition.
Old Jan 14, 2007 | 08:19 PM
That would be very helpful if I juice it.
Old Jan 14, 2007 | 08:53 PM
OBE1 95Z28's Avatar
If your thinking about nitrous down the road, you'll want more features than the 6AL has, namely the option to retard the timing.
Old Jan 14, 2007 | 09:35 PM
dannyum89's Avatar
That was my first mod as well. I later took it off because I noticed no gains plus I needed the room for my HID transformers. One week later I filled my NO2 bottle. First run I noticed that I was detonating like crazy. I put the MSD back in and ran nitrous runs without a prob. Sometimes its neccesary but for most its just a nice looking piece under the hood
Old Jan 18, 2007 | 05:33 AM
TransAm396's Avatar
Damn, I did not know that..think I should use it for my turbo 355?
Old Jan 18, 2007 | 08:52 AM
mzgp5x's Avatar
One of the first mods I did was an msd 6a and 8202 coil and wires. Did not detect an increase in performance. Then I got into FI. I've never had ignition problems except for...
Melting the rotor plastic on the opti. (Fixed with 1/8 alum rivets)
Fowled plugs (bad AFR [now fixed], and use of Zex spark plugs)
Its been running good.
Old Jan 18, 2007 | 10:52 AM
89TramsAmGTA's Avatar
On back to back dyno test on my L98 my MSD6A was worth two horsepower. I dyno'd 330rwhp and 370rwtq that day with an A4 to give some perspective.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
