Timing chain?
Old Jan 19, 2007 | 09:34 PM
NTRBTR97Z's Avatar
Timing chain?
How important is a new timing chain when going with a bigger cam? Is it something that can be done easily later ?
Old Jan 19, 2007 | 10:45 PM
Easily, later? That depends on what you think is easy. Very easy to do when you are swapping cams and recommended. Timing sets are a wear and tear item.
Old Jan 19, 2007 | 10:47 PM
95LT1conv's Avatar
why would you wait till alter if your allready there?
Old Jan 20, 2007 | 03:29 PM
hotrod18_69's Avatar
Not worth the risk.. Just get a new one and be safe..
Old Jan 20, 2007 | 05:43 PM
2000GTP's Avatar
I wouldn't take a chance, its senseless to invest the time and money to do a cam swap and leave out one of the more critical parts of the setup. You are going to have all of that stuff apart anyhow..
Old Jan 21, 2007 | 02:45 AM
Z-RATED94's Avatar
Replace the chain and gears, even if you can only afford the OEM replacement.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
