Opti w/o vacuum lines
The vent system is there to eliminate the ozone generated by the high votage discharge in the cap and rotor. Ozone causes corrosion, and damages rubber. A fringe benefit is the elimination of any moisture that may get past the flimsy seals.
how long will an opti last w/o the lines hooked up. I think I fried mine (see my other post) while waiting for the vacuum lines to arrive after I switched to a vented system. I am running the vacuum but having possible opti problems. Thanks!!
It's not something that would happen right away. It would take some time.
dluna333
15
Mar 13, 2015 12:30 PM
