gear removal question
Old Jan 18, 2007 | 08:19 PM
ZL1modified's Avatar
i have my timing cover off and i already have an electric water-pump...
what i wanted to know is can i remove the gear that runs off the camshaft gear to operate the mechanical pump?
i would like to remove it and install a plug into the timing cover...
is it possible and if so can you give me some info?
thanks
Old Jan 18, 2007 | 08:32 PM
Projectz28's Avatar
Moderator
yes its possible. If you already have an EWP then just remove the WP drive. You can try a freeze plug in there but I opted to take the cover to a local welder and he closed the hole for me. I dont have to worry about a leak now....
Not sure what size plug you would need, hopefully someone will chime in who knows.
Old Jan 18, 2007 | 08:35 PM
mdacton's Avatar
i just went to the parts store with the cover and showed them what I wanted to do...they showeedd me the cabinet with the freeze plugs and told me to find what I needed.
Old Jan 18, 2007 | 08:53 PM
LenT1's Avatar
They told me the same thing. I was unable to find one that fit though...there was one that was real close but I was unable to pound it in. I went with the next size down and jb welded it. I don't know how well its going to work until I get the car running
Old Jan 18, 2007 | 09:10 PM
now do you have to close the hole up in the block behind the timing gear?
Old Jan 18, 2007 | 09:26 PM
mdacton's Avatar
Nope, if anyone ask tell them its a speed hole
Old Jan 18, 2007 | 09:45 PM
LT1_383's Avatar
I did the same thing. It's held up for the last like 6k miles with no signs of leaking or anything.
Old Jan 19, 2007 | 08:28 PM
LenT1's Avatar
Awesome. I hear its not high pressure so im sure the jb weld will do the trick. Otherwise im going to have a mess all over everything!
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
Jul 4, 2005 05:00 PM
