96-97 lt1 in 95 T.A
Old Jan 17, 2007 | 11:57 AM
diamondhill's Avatar
Question 96-97 lt1 in 95 T.A
im looking to buy a lt1 out of a 96-97 z28, and i want to put it in a 95 T.A what do i need to do to make this work???
Old Jan 17, 2007 | 12:10 PM
ChevalierSS's Avatar
Plug the crank position sensor hole on the timing cover on the 96 motor, or use the timing cover from the 95.
Old Jan 17, 2007 | 12:16 PM
what about any sensors?? or are they all still the same? thanks in advance
Old Jan 17, 2007 | 03:24 PM
97WS6SCharged's Avatar
There won't be a plug on the 95 harness for the CPS. There shouldn't be an actual hole to be plugged, just an electrical plug that won't be utilized.
You will probably have to reuse the coil from your 95. Everything else should be the same.
Old Jan 17, 2007 | 03:37 PM
I was saying the same thing, I just assumed the sensor would not be there. If it is, don't connect anything to it....just make sure all of the wires on the 95 harness are plugged in somewhere.
Old Jan 17, 2007 | 10:54 PM
You need the swap the knock sensors..... the 100Kohm 96/97 OBD-II knock sensor will not work with the 95 PCM, which is looking for the 4.5Kohm OBD-I sensor.
You will not use the EVAP vacuum switch located on the passenger side valve cover of the 96. You can just leave the CKP sensor in the timing cover as a "plug".
If you still have you AIR system functioning, the holes in the exhaust manifolds on the 96 may not be the same diameter as the ones on the 95. The 96 will have a lot of extra components near the AIR pump, and an extra vacuum connection to the driver's side of the intake manifold for the AIR system (depending on whether or not the AIR "recall" was done on the 96). Check Shoebox's site for diagrams of the differences in the AIR system between different years.
Ringmaster72
Dec 12, 2017 10:12 PM
Noer
Feb 28, 2015 11:29 AM
Queens94z28
Dec 20, 2014 09:11 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
BLUETOPTA
Aug 24, 2002 05:45 PM
