Please help with a few quick questions.
Old Jan 16, 2007 | 01:48 AM
airfix's Avatar
Question Please help with a few quick questions.
Just need some answers from people that know what there talking about.
The cam will be a cc305 or a cc503.
1. Im asuming 1.6 sa pro mags will do me fine, I will not be reving past 5500rpms.
2. What valve spring combo should I go with.
3. 7.2'' hardend pushrods should be good right? stock heads and block.
4. Do I need new valve seals motor has 64k (not rough miles).
5. will my opti run of of the cam dowel pin its a 94 and I will be using stock opti and timing cover?
6. will a factory replacement timing set be ok, I will not be converting to a vented opti and 95+ timing cover.
Thanks in advance guys, Im asking all of these questions because Im 17 and this is all very new stuff to me i will be doing this project by myself so Im trying to do things right the first time.
Old Jan 16, 2007 | 06:46 AM
95LT1conv's Avatar
1. i would go with NSA and guideplates. why? stock can handle around 6k
2. might as well go with comp cams 918
3. i would check w/ a pushrod length checker
4. might as well change them if your changing springs
5. No, your opti has a splined shaft.
6. better get someone elses opinion there
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
