Car wont start...
Old Jan 15, 2007 | 03:28 PM
mcalus's Avatar
Exclamation Car wont start...
So I went out to start my car today and it wont start! Im not gonna lie I was pretty pissed! It turned over fine but it didn't want to start,it was like it wasn't getting any gas. I live in Michigan and we got a bunch of rain that basically froze my car over but im not really sure why my car wouldn't start.
Old Jan 15, 2007 | 03:33 PM
mcalus's Avatar
O and it might help to tell you what kind of car it is 1993 Z28 Camaro (LT1)
SO YEAH
Old Jan 15, 2007 | 04:05 PM
Guest47904's Avatar
Guest
Don't see much freezing other than maybe some water in the fuel filter. Try squirting fuel in the intake while some one cranks it over.
Old Jan 15, 2007 | 05:56 PM
Sweetred95ta's Avatar
Do all of the usuals ie check fuel pressure, check for spark, etc.
EDIT: I'll also add this link. http://www.mainstreamtopics.com/foru...p?showtopic=78
Old Jan 15, 2007 | 09:22 PM
mcalus's Avatar
Ok... ill try the gas thing first and see how it goes!
Old Jan 18, 2007 | 05:54 PM
bubba24's Avatar
mine did that and I wiggled the icm connector and it worked so if you know in the past if you touched that then maybe the prongs are looses in the connector and just bend them back and bit and put the plug back. But it could also be many things. Fuel spark...........
Old Jan 18, 2007 | 10:23 PM
mcalus's Avatar
So....My car started no problem the next day...Then today im driving the car and I tried to get up on it and it bogged down...But if I pressed the gas pedal lightly it would drive fine....then I tried it again and it staled and my check engine light came on...WTF??? Now its sitting in a parking lot and yeah....
Old Jan 19, 2007 | 12:10 AM
SS RRR's Avatar
Have you checked anything that was already suggested?
Old Jan 19, 2007 | 11:40 PM
mcalus's Avatar
I sprayed some gas in the intake and nothing...I talked to my dads friend that is a mechanic and he thinks its the Ignition Coil Pack....now my next questions is should I go with a cheap coil pack or go for the 50-60 buck one? My car is pretty much stock.
Old Jan 19, 2007 | 11:55 PM
LenT1's Avatar
I was going to suggest coil also. My car was doing that when my coil wire got loose some how and the connection tip was all coroded.
Then again my car did the same thing when my cat got clogged. I could drive it smooth but give it some gas and it would almost die.
Old Jan 20, 2007 | 12:07 AM
mcalus's Avatar
What Coil do you suggest? How much was it?
Old Jan 20, 2007 | 06:24 AM
Guest47904's Avatar
Guest
Coils are simple devices and you can get them anywhere. Doesn't make a difference who you get it from. But have you looked at yours?
Old Jan 24, 2007 | 10:22 PM
mcalus's Avatar
Ok...So my dads mechanic put a new Coil Pack on it and it still didn't start...He said its getting gas because he can smell it when it turns over, and he cleaned the #1 spark plug and he said it would of at least tried some kind of start if it was the plug and wires....
Old Jan 24, 2007 | 11:27 PM
Check for codes to figure out why the SES light came on..... makes a lot more sense than guessing and replacing parts at random. Since you have a 93, you can flash the codes on the SES light by jumping the ALDL pins.
Old Jan 24, 2007 | 11:29 PM
ponchoV8's Avatar
On two separate ocassions, first the coil connector, then the ICM connector went out on me, leaving me stranded twice. I guess they don't hold up well past 100K miles.
