compression with cc306
Old Jan 12, 2007 | 01:55 PM
kline454's Avatar
what should my cranking compression be with stock motor with cc306+1.6rr?
Old Jan 12, 2007 | 06:35 PM
19camaro71's Avatar
your cam size has nothing to do with compression ( i suppose i COULD be wrong on this) but a cam only controls how much the valves open. The compression happens when valves are closed, so if you have a stock engine (stock displacement and no head work with stock thickness head gaskets) you will have a stock compression rating.
Old Jan 12, 2007 | 07:21 PM
kline454's Avatar
yeah your cam does change your compression, valve over lap, the more valve over lap the more pressure is bleeds off.
Old Jan 12, 2007 | 07:24 PM
kline454's Avatar
my cranking compression is about 195psi with my 11.3 cr 383, just want to see what a stock motor with this cam would be.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
